- May 21, 2009
Awesome knife, the kind you want when it most matters
in the urban jungle. New Unused $125.00
The Benchmade 915-ORG Triage with a brightly colored and textured orange G10 handle. The safety orange handle makes this knife easy to find when an emergency is at hand. The G10 scales sit over sturdy 420J stainless steel liners and are secured with torx screw construction. There is a 440C stainless rescue hook that extends out the end of the knife and can be folded away into the handle when not in use. On the same end, you will find a carbide glass breaker. The plain edge blade has dual thumb studs and is produced from N680 stainless steel, a highly corrosion resistant steel. When open, the blade is secured with an axis lock that can be easily accessed with either hand. A black coated stainless steel pocket clip is included and can be used for right or left-handed tip-up carry. Made in USA.
Overall Length: 8.20"
Blade Length: 3.50"
Blade Thickness: 0.130"
Blade Material: N680 (Super Stainless)
Blade Rockwell: 57-59HRC
Lock: Axis Lock
Closed Length: 4.70"
Handle Thickness: 0.530"
Handle Material: G10
Liner(s): 420J Stainless Steel
Clip: Stainless Steel
Weight: 5.10 oz.
Blade Length: 3.50"
Lock: Axis Lock
Weight: 5.10 oz.
