Benchmade Apparition
Passed by a local gun shop yesterday and picked up a Benchmade Apparition and I thought I'd share my 1st impressions of this folder.
Please excuse the bad pics:
Specs (According to Benchmade's site):
Blade Length: 3.40"
Blade Thickness: 0.120"
Blade Material: 154CM
Blade Hardness: 58-60HRC
Blade Style: Wharncliff
Weight: 4.50oz.
Lock Mechanism: Locking-Liner w/Optimizer™
Overall Length: 7.82"
Closed Length: 4.39"
Class: Blue (Made in USA)
The model 670 Apparition is Benchmade's first attempt at an assisted opening folder which operates very much like the Kershaw/Onion Speedsafe folders by opening the blade via a thumbstud to a 30 degree angle and letting the tension bar take over. Benchmade calls their tension bar mechanism the Optimizer™. It's basically a spring steel bar that runs along the length of the inside handle spine which is secured in place and contacts the blade tang. When closed the bar is tensioned against the blade tang which gives a measure of safety against accidental opening while the knife is clipped to the pocket. Once the blade is rotated past a 30 degree angle the tension bar takes over and continues the opening process until it locks.
One of the features of the Apparition is the ability to remove the tension bar without having to disassemble the knife. 2 small hex wrenches are included in the box along with instructions on how to remove and install the bar. The larger hex wrench is to adjust the blade tension while the smaller one is used to loosen the setscrew located at the butt of the handle which secures the tension bar in place. Just open the blade, then loosen the setscrew and the tension bar slides out. Replacing the the tension bar is just as simple.
The knife is quite good looking with it's cast stainless steel bolsters and faux kudu horn scales and has a very utilitarian wharncliff-style blade shape that makes it an obvious Warren Osborne design. The scales are molded thermo-plastic which gives the illusion of kudu horn scales and is grooves provide an excellent grip. I personally would have liked G-10 or Micarta, but it doesn't feel cheap like other plastic scaled folders do. The bolsters have a nice brushed satin finish and the dual liners appear to be stainless steel although the Benchmade catalogue says they're 6AL-4V titanium. Lockup is solid with no play in any direction. There is a nice looking stainless steel pocketclip which is also removable. Unfortunately, left handers will have to look elsewhere as this is definately a folder made for right handed use.
More pics:
Some fancy filework on the spine:
Here's a pic showing the tension bar inside the handle (note the setscrew at the butt of the handle):
Here's a size comparison of the Apparition along with a Benchmade CQC-7 and a Lone Wolf T2:
Overall, I'm impressed with the Benchmade Apparition and I think it makes for an attractive addition to anyone's knife collection and more importantly, it's made to be used. The ability to remove the tension bar without having to disassemble the knife is a definate plus especially if one is travelling in areas that may look upon assisted openers as switchblades. Just like most assisted opening folders, once you begin to play with the mechanism, it's hard to put the knife down. It's that addictive.
Lockup is solid, though upon futher inspection I realized that the liners are stainless steel, not titanium as advertised in the Benchmade catalogue.
Thanks for the reveiw and the pics!
Here is the missing picture (one of your tags was messed up):
Thanks for the excellent review. I was just recently considering a purchase and your review has made my mind in favour. I have never been a fan of Benchmade (mostly the looks) but they seem to be well respected by most forum members. Here in Canada there are very few knife stores and we have to pay huge prices, so each purchase must be well planned. I think an Apparition is definitely on the way.
I just called TAD, they had them, but they are now sold out. They may have them back in stock, in a week.
Great review.
I actually handle an Apparition about two weeks ago and I was very impressed.
It seemed to be a very strong and well designed folder.
Allen.
StormLight said:
Just to clarify, you're saying it's shipped with the Optimizer installed. That's the "default", right?
Correct, the knife is shipped with the torsion bar is installed. It's quite easy to remove and the proper size hex wrench to remove the bar is included along with a torx wrench for the pivot pin. In order to remove and install the torsion bar, the knife has to be in the open position.
I received the knife a few days ago and removed the optimizer bar shortly after.It took about 30 seconds to remove it and I'm not experienced at all.With the optimizer bar in, I found the thumbstud very difficult to engage (it was beginning to bore a hole in my thumb) and it only snapped fully open for me half the time. Now I think it's awesome and would highly recommend it. If the "assisted opening" or whatever they call it was the big attraction for you, then maybe check it out in person first. It might have just been my knife.
I have the same problem with the thumbstuds on most of the assisted-opening Kershaws. Makers of assisted knives haven't figured out that normal thumbstuds don't work right: we need to get behind the stud, not on top of it. Might be why those flippers are so popular...
As far as not opening fully, you might need to adjust the pivot tension: it might be to tight for the "optimizer" to overcome.
aggiejason said:
How much are those bad boys going for? :D
List is $140; the few I've seen for sale have been for at least $120. Even on eBay, they're going for not much less than list.
They seem to be in very short supply. Even the big online vendors are only taking pre-orders; only a few folks seem to have found them retail! Lucky bastards...
I bought mine from a local gunshop/shooting range where it retailed for $109.99, but ended up paying just under $100 with my membership discount. I imagine it will probably be available for around $110 or a little less from online knife shops. I still think it's a great knife even at it's $140.00 MSRP.
