Benchmade Emerson SPEC WAR MODEL CQC7
Bobby B
No more Mr. Knife-guy
I picked up a used Benchmade Emerson CQC7.
I believe it to be a 970S.
The blade is about 3.25", ground only on one side. It has the BALI-SONG logo on the ground side and the Emerson Spec war model CQC7 on the other. Unlike pictures of the 970s I have seen, it also says ATS-34 on the flat side. Is this unusual? Is there a trick to sharpening the 1 sided "chisel edge"?
Thanks,
Rob
The two that I have are marked identical to yours, so nothing unusual there.
I have only used one of mine, and I sharpen it on a DMT diamond whetstone. No problems keeping it scary sharp.
A good find. The 970 was very successful for BM until Ernie Emerson started up his own factory company.
Sharpen at about a 30 degree angle on the chisel side only. Then strop off any wire edge on the other side.
knifenerd said "Then strop off any wire edge on the other side."
Hey wait a minute, I'm not dead yet!!!!!
Seriously though, that's a good find Bobby B. My BM CQC7 is marked exactly like yours as well. I have found that if you hold your knife in your left hand (assuming your right handed) and holding a sharpmaker rod in your right, you can "freehand" sharpen a chisel edge pretty easily. It just seems easier to hold the angle that way.
Bobby, I own both a 970 and a 975. The 970 is a great knife. Knifenerd is correct on the sharpening of this knife with about a 30 degree angle. I will have to try and use wireedge's method next time it needs a good sharpening.
Thanks guys. I don't know what they're worth, but I paid $50 shipped for it...
