Benchmade Mini Grip vs Spyderco Native
I’m a relatively new knife enthusiast and recently purchased the Benchmade Mini Grip 555HG and Spyderco Native SC41PBK. The Mini Grip I purchased from an online knife retailer for $57 (before shipping). The Native I found at the local Walmart for $40 (before taxes), although I’ve been told that it will be offered online only from their website in the near future.
What follows is my attempt to write a comparison review for both knives to outline their strengths and weaknesses.
BLADE
The Benchmade Mini Grip uses a 154CM blade while Spyderco Native features S30V, which from what I understand is a bit more of an exotic metal. I’m really not knowledgeable enough to know which is better technically, they both seem very sharp from the factory. Because I just purchased these recently, I really can’t tell how long each blade will hold their sharpness.
Both blades feature a round thumb hole in the blade for easy one handed opening. Apparently this is a trademark Spyderco feature and I was glad to see it on the Benchmade Mini-Grip for 2007, as I feel this makes the knife very easy to open and was one of the main reasons I bought it.
As you can see from pics, the Native blade is wider with a spear point pattern, however, this makes the tip of the blade thinner and possibly more fragile when used for such tasks as prying. It seems this was purposely done by Spyderco as a design feature and to reduce weight. The Mini Grip uses a more simple design that also appeals to me.
I’m going to call this even, because I don’t have enough knowledge to perform objective tests and haven’t had each knife long enough to determine durability and sharpness retention.
Edge: Even
HANDLE/ERGONOMICS
Here the Spyderco wins hands down for what is a subjective reason on my part, the Native fit my hand like a glove because of the two finger coils. Obviously this will vary among users depending on the size of your hand.
Notice in the pic below that the first finger coil forces you to hold the handle farther forward and allows the entire handle to fall in your palm. The Mini Grip handle when held properly doesn’t seem to extend far, and my pinkie finger can’t rest on the handle. The Native handle extends well into the palm and slightly past the pinkie, resulting in a very secure and natural feel. It's obvious a lot of R&D went into this design at Spyderco.
Both have anti slip textures on the handle, although the Native extends its web like texture over the entire handle, resulting in less slip overall. The blade serrations for the thumbs are equally functional, and the Mini Grip extends this into the handle, making it a bit more versatile. Overall though, the Native is clearly the winner in this category, it really does feel like a natural extension of my hand.
Edge: Native
ACTION/LOCK
I could tell right away that the action of Mini Grip is one of its strong suites. It opens with a lot less effort and feels extremely smooth. The Axis lock engages well and with very little resistance. The steel liners and what appears to be two washers on each side of the blade at the hinge contribute to the smoothness of the action, features that the Native does not have.
The Spyderco uses a David Boye Dent and once engaged makes a much louder and reassuring “click” sound than the Benchmade. However, there is a bit more resistance when opening the blade versus the Mini Grip, and more force is needed to press down the release mechanism.
Edge: Mini Grip
CONSTRUCTION/QUALITY
Again, construction seems to be a strong suite of the Mini Grip, and probably explains why it costs more than the Native. All the screws are user customizable while the Native screws are not (except the clip screw which is covered in the next section).
The Benchmade has steel liners and the aforementioned two washers between the blade and liners on each side to ensure absolutely no side to side blade movement and butter smooth action. One test I did to the Spyderco was to press down the blade release and noticed that there is definitely some side to side blade movement. The Mini Grip on the other hand exhibits no play whatsoever when the AXIS lever is engaged.
The technical specs indicate that the Native uses FRN nylon polymer while the Mini Grip uses what Benchmade calls "Color Valox" which seems to be a bit heavier. I have no idea if one is stronger than the other, although the handle of the Mini Grip feels a bit more substantial and slightly tougher.
Edge: Mini Grip
CLIP/STORAGE
Both knives store in your pocket tip up, which is what I prefer. The Mini Grip clip is very stiff to the point that the force against the handle texture will cause damage to pants over time. The Spyderco clip is much better designed with less force and is actually a bit longer.
The Mini Grip uses three small screws to secure the clip while the Spyderco uses one large screw that can be easily loosened with a coin. One thing I didn’t like is that the Native clip screw is easily prone to lose its paint layer, which detracts a bit from its appearance, especially since I’ve only owned it less than a week. Functionality is more critical though and therefore the Spyderco takes this category.
Edge: Native
CONCLUSION
If you add up the preferences of the sub categories above, you can see that the matchup is even, and both knives have their own unique positive attributes. My subjective conclusion however gives the slight overall edge to the Mini Grip, because I personally value the action and construction of a knife more than the other characteristics. Both are great knives and I’m glad I purchased them, but in the end if I had to choose one I would go with the Benchmade Mini-Grip.
Thanks for taking time to read my review, I hope you enjoyed it.
TECHNICAL SPECIFICATIONS
6.78" - Overall Length
3.87" - Closed Length
2.91" - Blade Length
0.100" - Blade Thickness
154CM - Blade Material
58-61 - HRC Blade Hardness
2.56oz - Weight
7.00" - Overall Length
3.94" - Closed Length
3.13" - Blade Length
0.125" - Blade Thickness
S30V - Blade Material
58-60 - HRC Blade Hardness
2.65oz - Weight
Great review! Good write-ups and nice pictures. :thumbup:
I'm a lover of the Native myself. ;) I really like the ergonomics. With the finger choil on the blade, I find the Native to be really comfortable.
Thanks for the comparison. While the Native is pretty much my favorite knife, I do have my eye on a Griptilian of some sort.
What a great review!
I am looking a the Native as a future purchase.
Since this is relavent to the Native review.
Could someone comment on the difference between the S30V and the VG10?
Thanks,
Neeman
VG-10 - easier to sharpen, don't hold edge for as long as the S30V. Both should be find even if you do a lot of cutting daily.
I have both, and they both have some great strengths. I love the ease of opening with the Mini Grip, and the blade shape works just fine. The Native is a great hand filling design and S30V can get seriously sharp! I ran mine over my diamond sharpener last night and hair just fell off my arm with no effort at all.:eek:
I have both as well, I have to say the I tend to carry the Mini Grip more as I really like it's smooth action, plus I think that it's blade tip is stronger than the Native's.
As stated by others, both are very good knives for the respective cost. It's really down to the individual's own preferences as to which one they choose.
Good joy on the review sleeper3.
Cool review! I think the Grips handle feels hevier because of the steel liners. Would love to see Mini Grip vs Delica4 review. I would love to buy a mini grip, but Benchmade is Expensive in South Africa and VERY limited. Thats one reason why I prefer Spyderco. Easier to come buy and good value for the money!
Great review Sleeper3. I am quite a fan of the Mini Grip
I never bought a Native because the defined finger groove and choil put me off. However, I really like the Delica (3 series) and Calypso Jr Lightweight, which are of similar size and construction to the Native.
They are all ideal knives for day to day use.
Sure Gus. Top to bottom they are:
556 in 440C (although they are now made in 154CM)
Mini RSK Mk1 in S30V (558-400)
Cabela's exclusive in D2 (556BKD2)
555HG in 154CM
Limited Edition Mini RSK Mk1 in M2 High Speed (558M2-600)
Thanks for taking the time to write that up.
My experience is the same. Almost every Spyderco in my collection has lateral blade play when locked open, including two Natives. My only Benchmade is a full-sized Griptillian 551 and it has no play at all.
Best Wishes,
-Bob
In the spectre of similar price points, I'll always choose the one with the axis lock. Just a presonal preference. Blade steel on smaller knives like these don't mean all that much to me as they will not see much extreme duty, however should it, the axis lock adds for that little extra added security, at least mentally. When there is blade play like on lock backs and some liner locks, you never really feel 100%, at least I don't imho. Again nice review!
Matador-
In terms of how you constructed that review, I was impressed!
An excellent job, indeed. :thumbup:
Here's hoping you post more often.
Thanks for the nice comments guys.
I want to emphasize that I'm a fan of both Benchmade and Spyderco products. I continue to be impressed by the wide selection from both companies and look forward to learning more about them. Benchmade seems to continue to concentrate on its excellent AXIS lock mechanism, which I personally find amazing. Meanwhile, Spyderco has some very interesting ideas, and their use of the H1 non rust steel is quite impressive.
My current favorites are the Benchmade 710 (I want one bad) and the upcoming Spyderco Stretch2 and P'Kal. Speaking of which, the pics I found on this page were simply amazing:
http://www.spydercollector.nl/index1.php?pagina=news&id=144&ex=none#article9
Best Wishes,
-Bob
And I thought I was the only one who loves the 551 full.
Great review btw. I still prefer benchmade and buck though.
