^ thisI currently only have one BM in S30V. It is a Mini Grip from the custom build program. I carried that one daily for awhile, and while it hasn't seen hard use, it never chipped on the factory edge.
I re-profiled and lightly polished the edge, and while it hasn't seen very much use since, it is still chip free.... Some people complained in the past of chipping, but IIRC the issue subsided after being sharpened once or twice. Benchmade does a very good job with heat treating on all of their steels.
Out of all the BM's I have owned over the years, the only one I have had that had chipped, is a Cabelas Mini Grip in D2. In all fairness, I bought the knife used and it came to me that way, so I have no idea what kind of use it had seen to make it chip...
I re-profiled and worked on the edge twice, and was able to get all of the small chips out. I've been carrying it for a few months now, and it hasn't been babied, but it is still chip free.
Don't get caught up in everything negative you read. Especially about the various versions of blade steel. You will find their are some people who will complain about something, even though they may not have actually used it, or used it long enough to form a true opinion. Or, some will complain about certain steels claiming little, or very easy use, only to find out later, they actually were abusing the knife.
Use the knife the way you normally would, and see how it holds up for you, under the conditions you use it for.
We have a member here who has done very extensive testing on most of the steel used today and from various makers. His reviews are great, and he always posts a lot of pictures during the process...
Click on this link http://www.bladeforums.com/forums/s...based-on-Edge-Retention-cutting-5-8-quot-rope and it will take you to his thread. There is a lot of great reading in it.
Just sharpen it really well, and after that any chipping issue should be gone. Sometimes during sharpening, the very edge gets a little too hot and makes it more brittle, but once any chips have been sharpened out, it's good to go.Hi Everyone,
Just picked up a Volli and have to ask about the S30v blade steel. I have heard that it chips pretty easy.
What can you folks tell me? I really don't know much about steels.
Thanks.
I totally agree. I have had a lot of different steels.most r very good.im using s90 right now.people say it hard to sharpen. I dont find it to be true.if u work at it it gets sharp just like any other.but it holds an edge for a long ass time.^ this
Sometimes during sharpening, the very edge gets a little too hot and make sit more brittle, but once any chips have been sharpened out, it's good to go.
Wouldn't heating the edge make it softer?
Depends on how you do it... heat above upper crit. temp. and then cool at a slow, controlled rate gives you pearlite formation. That's annealing and yes, you can soften metal that way. However, heat above upper crit. temp. and then cool in a hurry and you end up with a bunch of martensite, which is harder and less ductile (cool quickly = not enough time to form pearlite, stuck as martensite instead). That's basically quenching right there, heat and then cool quick to lock in martensite to make it hard. Then temper to add toughness as desired.
If I had to guess, the argument that "burning" an edge while sharpening causes chipping goes something like this:
Edge is relatively thin and so gets hotter than people expect while sharpening, especially on power tools.
Edge gets in the range of the upper crit temp and excess martensite forms, making it harder, brittle, and less ductile (more chip prone).
Edge is thin enough and heat is localized enough that it cools down in the air fast enough to lock in the extra martensite - basically air quenching.
That would leave you with a chippy "burnt" edge.
