Benchmade sharpening angle?
Okay... I recently got my 2nd benchmade knife, a Nitrous Stryker 913SBKD2, and I have a question... how should I sharpen my new knife? I have a 700 grit diamond plate and 1000 grit ceramic rods. what angle should I sharpen with? 30 degrees? thanks in advance for the help.
You can take a sharpie marker and color the edje....just the secondary bevel....the final grind. Then go to the steepest angle you have (maybe 30deg?) and take a few light passes. Inspect the edge and see how the marker is grinding off. That will give you an idea of what angle to proceed at.
Most BM's in my collection are ground between 30 and 40 degrees, and rarely are they the same on both sides. Usually they're off a degree or three from one edge to the next. Depending on the blade shape, primary grind, and intended use of the knife, I lean toward more shallow angles (less obtuse). When the knife reaches the point where it needs its first "real" sharpening, I'll usually regrind both edges to a uniform and steeper grind, sometimes aiming for about 25 degrees (12.5 or so per side).
Thanks guys
I have another question. after sharpening, if I want to strop the blade with printer paper, how exactly should I do that? I know that you can put a few layers of paper on a flat surface, but how many strokes should I do per side?
Thanks guys
edit: sorry for the double post
i do it either on my jeans or on cardboard. i use notepads also but only when i have softer steel. just do 10 per side and check the bur
Cookies,
If you're doing it correctly, then go 10 per side (as stated) and keep on going. You can strop until you're bored with it and the edge will only get smoother and, again if done correctly, sharper.
If you're stropping incorrectly, do zero per side.
