Benchmade Vex Adjustments
Well, i just bough the vex as some of you know. I got a 1.5mm(frame screws) and 2mm(pivot screw) hex keys to adjust it. What i did was i loosened up the pivot screw but i notived the blade hit the inside. So i tightened it back up. This time too tight. So what i did was i pushed the tip towards the frame but it didnt "click" down. So i loosened it in small incriments until i did. I found that this loosened the blade up a bit more in the action. Then i went around the frame and very carefully tweaked on the bolts, some were tight some werent. I carefully tightened them up until they were all clicking, which meant they were tight enough. I'm kind of growing on this knife.
