Indeed - not cheap - over a grand, IIRC.
I have two huge hardened D2 cutters from a paper mill. They used to shear reams of paper to exact size.
They are 36" long by 1" thick and 5" wide. The single bevel goes 3" up the side. There are 1/2" recessed bolt holes every 4" along the upper part.
I have thought of having them water-jet cut in half and building two pieces into the end of a work table to make a giant paper shear for cutting sandpaper and thinner sheet metal
And, taking the other two pieces and making a compound leverage style shear (somewhat like the Beverly). I think if I the water-jet guy cut one edge off so it was about 1/2" wide, I could grind that edge angled at 5 degrees as the cutter/shear ( might have the water-jet guy make this cut, too), and use the spine of the other piece as a flat surface for the shear edge. I think it would shear 1/8"-3/16" steel. With the pieces already pre-drilled, it should be simple to bolt up.
