- Jan 31, 2006
I give all the credit to member echoscout on this board...
He helped me earlier by saying,
"If the pivot screw is properly tightened and the blade is still off center the easiest fix is to bend your knife. Open the knife and wrap the blade with something so you do not cut your self. With the handle in one hand the blade in the other give it a little bend. Close blade to check position of blade if not where wanted repeat till blade is centered the way you want. I use this method to keep all folding knives centered. Have a good one."
this was when my knife wasn't falling center and touching the liner slightly, but I also noticed that this also effects where the liner lock engages the tang. IE.. if your liner lock is traveling to far you can try this.
I would like to add you are not actually bending the blade, but just applying some pressure. I do this by placing the blade on the carpet, with a towel over it for safety, and "bending"
This means so much to me because I am little OCD about things and want my blade to fall dead center upon closing,and my liner lock to fall dead center (unless it is the break in period)
thanks again echoscout :thumbup:
