bending a liner lock
Hey I was just wondering if bending a liner lock slightly to tighten the lick up will cause structural damage to the integrity of the steel liner?
It's not a great idea unless you're very cautious. Small moves! I've tweaked a few linerlocks and framelocks by bending them with success in my time. :)
You could ruin your knife though so proceed at your own risk. ;)
thanks guys. It ended up working, but I was just wondering if it would beaken the liner?
It'll be fine. You'd have to really bend it out of place (like 90º) and bend it back. A slight tweak won't hurt it a bit. Remember, it's spring steel. It's designed to flex.
I bent my spyderco military because it had bladeplay. Now I can hardly lock it. And spyderco dont ship parts :0/
if you are bending it just to make it stronger, i suggest another alternative. try the paper mod....basically you slide a little piece of paper between the lock and g10 (or w.e the knife handle material is).....basically all it does is act as a wedge so the liner lock would be harder to disengage......that wat i did to alot of my benchmade liner lock folders.
