benefits of titanium...
So... Other than weight and corrosion resistance, what are the benefits of titanium over say stainless steel (or other) handles?
peace love arch
OK OK...
What I'm looking for is pros and cons. For instance:
Is titanium stiffer than Stainless, and the resulting con to this being it is more brittle and could break instead of bending?(less malable)
Is titanium harder than stainless, being more durable to nicks and dings of daily use?
And finally...
COULD Stainless steel be MODIFIED to be a better handle material than ti? What about Talonite?
Though I don't own a Sebenza, I'll take a stab at this. Titanium is lighter than steel of equivalent strength (N.B. it is also thicker). Titanium is corrosion resistant to a greater degree than steel. Titanium also galls to other metals under pressure, making it better in a lock (I believe; I may be wrong). In handle thicknesses, I think titanium is plenty strong; in handle liners where thickness is much more limited, you will see more steel (REKAT, for example) due to its better volume/strength ratio. Talonite would make a prohibitively expensive handle material, aside from any other flaws it may have. I believe it would also be extremely difficult to machine.
To answer some of your other questions, generally speaking the steels that we're most familiar with in the cutlery world are both stiffer and harder than titanium.
One of the major benefits of titanium that hasn't been mentioned is that the figures for its tensile strength and its yield strength are very close to one another.
Very simply stated, yield strength refers to the point at which a material will take a permanent bend (become plastically deformed), while tensile strength is a measure of when the material will actually break (or pull apart). As a general rule, most steels will reach their yield strength well before they reach their tensile strength. Thus it's easier to bend steel without breaking it. But this also carries implications with regards to eventual failure due to fatigue and other factors.
With titanium, on the other hand, you must come very close to breaking the material before you'll get it to take a permanent set. When discussing integral lock bars, for example, this can be a very good thing as it allows for an excessive number of locking and unlocking operations with little to no resultant metal fatigue.
Semper Fi
-Bill
[This message has been edited by Bronco (edited 03-29-2001).]
