So UPS dropped off my Beretta Harsey folder this evening. All I can say is, impressive! Obviously I haven't had the opportunity to test it out yet, so the observations printed here will mainly deal with first impressions.
As with all knives I get, the first thing I did was to simply look it over. Checked to see if the blade was centered in the blade channel, and it was as perfectly centered as it could be. Looked over the fit/finish of the G-10 to the titanium liners, and the fit was also as good as it gets, and this includes the small cutouts on the liners that have to be on the G-10 to match it up. No gaps between the liners and G-10. I did notice that the G-10 and the clip are held on by larger than usual screws, I think these were 4-40's instead of the usual 2-56's. Pivot screw was seated well within the handle. The G-10 was the Spyderco type, for lack of a better word, grippy, let very easy on the hands, and pants!
Next step was to open it. Thumbed it open with the thumb studs/blade stops. The titanium liner came over behind the blade tangso that the left side of the liner, and left side of the blade tang were flush, leaving a little over half of the thickness of the blade tang for liner wear. A spine tap produced solid lockup with the liner staying in the original lock up position. The blade moves on bronze washers and is very smooth throughout the opening. I have tightened the pivot a little to get it where I like it to be, and though harder to open, it is still very smooth through the cycle. The pocket clip is set for tip up carry only and will requiere a little work by me to make it better suited, read that as making it set deeper in my pocket, and I think I have an idea that will work.
The blade is S30V steel and it is a spearpoint with a sharp tip. The grinds are great on both sides and are even. Edge came razor sharp, and it is flat ground from the flats down. One thing I like is that the blade tang has a little overhead ledge that prevents the liner from moving up on the blade tang. The front side of the blade is marked "Beretta" and the back side is marked "CPM-S30V"; "William W. Harsey Design"; and then a card shaped rectangle with a pine tree? and three dots over it with the word Italy underneath. This is located on the blade tang. Guessing this is the manufactures mark. Anyone familiar with this mark?
Another thing I did was to measure everything as the different sites I looked at this on had different measurenments. So these are the official measurements;
BLADE LENGTH- 4.25"
HANDLE LENGTH- 5.25"
OVERALL LENGTH- 9.50"
BLADE THICKNESS- .156"
LINER THICKNESS- .070"
WEIGHT- 6.5 OZS
TOTAL WIDTH- .557"
I didn't measure the total thickness, but will. I will say that the knife is thinner than I expected, and that makes it ride flatter in my pocket, which I like.
Like I said earlier, this is just a first observation post. So far I like what I see, and know that I certaintly got my money's worth on this purchase!!:thumbup:
:thumbup:
