Hi BF,
I'm not sure if this should be in GKD or Maintenance & Tinkering, so please move if necessary.
I've been reading up on knives for about a year now, and one of the ideas that I got ingrained in my head is that recurves are not as good as straight for the portion of the blade between the ricasso and the belly, just like nylon washers are not as good as bearings (that's a whole 'nother discussion). If I see a new design with a recurve on it, I'm instantly turned off.
But I've been thinking about it and I may have been too hasty with my assessment. The only drawback I see with recurves is that they are moderately more difficult to sharpen when using flat sharpening stones. If using a Sharpmaker or a sharpening belt, there is no difference in difficulty.
The reason I'm thinking about this is that when I'm using the Ken Onion Worksharp, it will do two things that if you're not careful.
- round the tip
- put a recurve in your blade
I use a KO Worksharp and a Sharpmaker for my blades, and if I inadvertently put a slight recurve on my EDC, I'll actually grind away the rest of the blade to even/flatten it out. But why am I doing that?
Recurves
- increase the cutting edge per constant blade length
- increase the power of a draw cut due to the lower attack angle
- push material closer to the recurved radius, thus making a more efficient cut.
My EDC is a ZT0562, which has a flipper tab, so its not good on a cutting board with or without the recurve.
I'm not planning on purposefully putting a giant recurve on my blade, but letting it happen naturally and just accepting it. I might get a slight performance boost out of it. I'm thinking of something like the gentle curve on the Benchmade 710.
Thoughts?
(not my pic, from bladereviews)
- round the tip
Recurves
Thoughts?
