- Mar 16, 2019
What is your best argument for carrying a Tomahawk vs. a Machete or larger "chopper" knife? Assuming it has to be one or the other for some reason.
100% depends on the context of use. What are you using it for, where, when, how are you transporting it there, and of the total range of tasks you're using it for, what is their ranked frequency, intensity, and duration? Without that information you're basically asking "what should I use--a screwdriver, hammer, or wrench?" without stating if you intend to use it on screws, nails, or nuts/bolts.What is your best argument for carrying a Tomahawk vs. a Machete or larger "chopper" knife? Assuming it has to be one or the other for some reason.
What would you say a tomahawk is for?A tomahawk or a more useful regular belt axe ?
I'd Choose a good hachet / belt axe or a boys axe over either two.
If it's even on the table that going to be because the situation will call for chopping and splitting, and that's what an axe is for.
A knife is a cutting or fighting tool, a machete is a brush / bush / vegetation clearing tool, and an axe is a wood processing tool.
You're completely correct. I guess I was hoping that the answer would be along the lines of "if you're doing X then machete, but for Y a tommy" etc. So I agree completely with your point.100% depends on the context of use. What are you using it for, where, when, how are you transporting it there, and of the total range of tasks you're using it for, what is their ranked frequency, intensity, and duration? Without that information you're basically asking "what should I use--a screwdriver, hammer, or wrench?" without stating if you intend to use it on screws, nails, or nuts/bolts.
that’s not the question you asked, but it’s the answer I have.
There's a lot of variation dependent on which specific models you're comparing, but generally a slip fit axe or a tomahawk will be the best suited to chopping immobile woody targets and doing splitting work and has lots of use options with swapping handle lengths or using just the head as a standalone tool. A machete in the default 18" length will be the largest but also the best jack of all trades, in addition to being the only of the three truly well suited to clearing lush vegetation of any meaningful quantity. While still fairly light overall it can chop woody targets, and is better than a 'hawk for small diameter stuff that will quaver when struck, but is the most cumbersome for knife-like use on finer work (though it can still do it.) The chopping knife category can usually best be thought of "a large knife for large knife things, but also it can chop and do *some* limited brush clearing" but it falls short of the slip fit axe and machete in those areas respectively. Both machetes and large knives can still perform modest splitting work, with the chopping knife category generally doing better due to having a greater spine thickness. Making wooden wedges is usually the best way to go if splitting anything calf thickness or up.You're completely correct. I guess I was hoping that the answer would be along the lines of "if you're doing X then machete, but for Y a tommy" etc. So I agree completely with your point.
An actual tomahawk is historically a weapon for the most part, however these days they're basically like a hatchet but worse because the head profile isn't right for wood duty.What would you say a tomahawk is for?
Incidentally (since you've gone off track but it's interesting so I'll continue) I have never used a hatchet, despite thousands of days in the woods with fires. I haven't even held one since I was a kid. I'm not saying you're wrong. Obviously people use hatchets. I just can't figure out for what?
What would a tomahawk do better than a hatchet?
What is your point? Because that doesn't address my question.Depends on the specific tomahawk. While some are not at all well suited to tool use, many on the market today are really better classified as small slip-fit axes, which do off advantages and disadvantages over common hatchet models.
Fighting , throwing , slicing .What would a tomahawk do better than a hatchet?
He's saying that tomahawks aren't all very good at being used as hatchets.What is your point? Because that doesn't address my question.
I will buy into slicing.Fighting , throwing , slicing .![]()
I have one of these . Kinda like a big hawk .I will buy into slicing.
So a tomahawk makes a better knife than a hatchet does.
