Is Ballistol food friendly?
I use coconut oil. Solid at about room temperature. Food safe, extremely lubricating, easy to find, relatively inexpensive, and smells good too! I got the idea to use it from a discussion in another forum about using it as a gun lube in tropical climates. I figured it might work on blades too, was right. It's kept my carbon Mora shiny and the rust-prone SR101 on my Rodent Solution mirror polished. Works well in the kitchen to boot.
HDCI seems to be more water resistant. However you spray it on and let it air dry , over the course of a day or two. Then remove the residue.
EDCI works really well. You just spray it on and wipe it off immediately , making it easier to apply.
Nowadays I use HDCi as a first coat , and then followup/weekly maintenance is done with EDCi.
