Recommendation? Best Budget Hard Use Knife?
John Phillips
Platinum Member
Looking for suggestions for a hard use budget pocket knife. I’m thinking of using this for general construction work, camping, hiking, general hard use around the house and property. I want to get something I can even pry with(gently) and not worry or feel bad for prying(before I get all the comments…yes, I will get a prying tool if needed for a job rather than use a knife if the jobs needs an actual pry tool). I’m thinking about the Recon 1 Tanto Serrated in 35VN as a top choice but I wanted to get some other ideas. I can get a new Recon for $100, any other suggestions at this price that might be a better consideration or better value? Don’t need any fixed blade ideas, I already have that covered!!!
I have the Cold Steel Ultimate Hunter in S35Vn and the Air Lite in AUS10. Both seem solid and are equipped with the Triad lock. The Ultimate Hunter is slightly over your budget and the Air Lite is slightly under but either one would serve you well.
Looking for all brand suggestions as well, not just cold steel.
most quality brand folders will do fine for all tasks except the limited prying ya asked for. thats why i picked the sr1 due to its very thick blade stock and tri-ad lock to help on that task.
limitations is your top end price point and limited prying requirement. thats why your getting all cold steel recommendations so far.
I like the Recon 1, but you could buy two Ontario Rat 1 or 2's for the price of one Recon 1 and be ahead if you break it...I've seen them beaten up pretty good, they can handle more than you might think. Another good option for a cheap beater is the often overlooked Ontario Utiliac 2
If you want a folder for prying I cannot think of any other options than Cold Steel.
If you are accepting of a clip point (keep in mind that as an occasional knife abuser I have yet to break off a blade tip), consider the Buck 112 LT. Lightweight, inexpensive, easily replaced, rides nicely in the pocket. If you do not take to it, I will buy it from you!
Hello john. I used a cold steel recon tanto on site, wrecked blade coating, as expected did not phase blade at all. This was used for everything from cutting brick bands to sharpening pencil, only thing i will say until you get used to the lock, you will swear its broke. Gar
Cold Steel 4 Max Scout at Knifeworks. You'll thank me later!
SR-1 Lite is pretty cool too, but the 4 Max has better geometry and better steel. I still got an SR-1 Lite just because it's ridiculous, so why not? LOL
Been happy w/ my CS Finn Wolf as a budget beater. Still working on taking that huge scadi edge back, but it's thick and mostly sharp, and still in the $30+ dollar range.
S35VN is not a tough steel. Consider reading https://knifesteelnerds.com/2020/06/15/what-is-the-best-budget-knife-steel/ and see this chart from the same site.
Understood and agree. I’m definitely open to higher budget options. I have plenty of $200-$600 folders but I’m typically more careful with these. I want to be able to not care if I have to use and abuse a hard working knife.
