Best knife for pool water?
Do regular "dive" knives work? And if so, whats a fairly good one? Or do I have to get something special to put up with the chlorine?
Try one of these
You can get one by clicking here
Recontech,
Regular Dive Knives work fine, I've done a bit of training in pools over the last 1.5 years and as long as you rinse/soak gear in freshwater after it's usually fine. If you're really worried about it you may want to coat it with some Marine Tough Cloth. If you want a different material Ocean Master makes a Beta Titanium knife, which is what I carry. It needs a little work on a sharpmaker when you get it, but otherwise a good knife. Underwater Kinetics also makes a great knife, called their Blue Tang model. It originally came only in steel and cost about $50 but I just checked and discovered that they are now being produced in Titanium as well for $90ish. Good Luck.
Lagarto
http://www.gagaproducts.com/Qstore/Qstore.cgi?CMD=009&DEPT=1048116368&CAT=1048116428
Could always try the Cat Tanto from Cold steel.
http://www.coldsteel.com/92cat.html
43% Zytel, blade and all made of that stuff not sure how sharp it is but you can easily shape the blade to what you want and use it in the pool. It should not react to anything. I'm almost sure Zytel is neutral with just about everything. And for the cost where can you go wrong.
You carry a knife in the swimming pool? I carry a knife in lakes, rivers and oceans, as well as dry land of course, but a swimming pool... do you own it yourself? If not, the person who does may be afraid you're going to pretend to be a shark play a few rounds of "get the slowest kid".
Well I like my stuff to work underwater, in all water, such as my Surefire M2, Glock 22, H&K USP, and now a knife, Casio Triple Sensor watch, etc...
