- Nov 20, 2016
I am coming from the world of KME. The best position to put the jaws was a midpoint between the start of the blade spine to the tip and at an angle where the jaws are parallel to a line drawn between the tip and heel of the edge. Then do a magic marker on the edge and see what you get and adjust as necessary. For me, most of the time, this worked without much correction.
On the WE both the instructions and most, if not all, of the videos show you set the knife spine on the alignment stops about mid way along the blade. That puts the knife spine parallel to the WE base, regardless of edge geometry. Then do the magic marker thing and adjust the knife position, horizontally while keeping the spine on the guide, to get an even edge. From the videos it looks like you get some good edges out of this.
But why do both of these methods work, which one gets you closest to the right position. One advantage of the WE method is it gives you an easily repeatable position.
