The river is in the AMAZON jungle.
Omar
he means amazon . you might check into ryobi rotary tools. they make some with quite a bit of power and you can get a flex shaft for it. just google ryobi rotary tools.
The Foredom does not run as fast as a Dremel. For myself, running at a lower speed gives me a little more control and I don't burn the material as easily. Since it runs a little slower, it removes material slower. The Dremel goes fast. Mine runs at 25k rpm. I like using it with the abrasive cut off wheels when cutting metals and materials that don't melt or burn.
Don't worry about having a lot of power tools. Many of us here started out with some hand tools. It just takes b bit longer. My first few knives were made with hand tools and used a drill press at work to drill holes to pin the scales on. I find that Micarta is fairly easy to work with and tools. You might pick up a coping saw to cut out the scales (they can follow curves better).
Do you have some files? You can do a lot of rough shaping pretty quickly with coarse files.
Ric
