There is actually allot of stones and strops available for the KME. Diamond, ceramic, cholera water stones, kangaroo strops, strop man makes custom strops for it, the diamond emulsions they have available are awesome. I'm curious what issues need to be addressed?
Yes , but everything you just listed is available for the edge pro plus a whole lot more. Nubatamas , Shaptons , European Naturals , Japanese Naturals , Diamond Films , Atomas...
Im not knocking the KME , its a great setup for the money , but its a young system with a young crowd. As that crowd learns and develops Ken and Ron will release more and more for it. But currently the aftermarket for the KME is a ways behind both the EP and the WE.
-Ohallum mentioned the minimum angle ,
-My other issue is the amount of play between the system and the base , not a huge deal given the rod system is attached to the blade holder , but there is quite a bit of play visible.
-Base does not seem to sit firmly in a single spot , no way to mount it more securely.
-I am also curious to see how well the ball pivot on the rod guide holds up. Some type of Nylox or something I believe? Theres a lot of abrasive being release there and over time I believe it will develop play. Same as the EP will
-Then theres the blade clamp , not the most condusive to doing large blades (in excess of 12 inches say) With no way adjust for any curvature of the blade.
-How do you accommodate for variation in stone thickness? You have to use an angle cube or a sharpie every single time you change stones otherwise as your coarse stones wear they will get further and further away from your fine stones.
Just off the top of my head.
Again , I am not knocking the KME , Nor am I looking to start a pissing match over who believe what system is better.
