I have a Camillus paratrooper knife, the auto with clip point blade and a paracord cutter. I suspect the steel is a 440 series stainless. I am not going to be jumping out of any airplanes (I did at one time, but I got smarter
); however I like to sharpen each knife for its intended purpose. I decided to sharpen the clip point blade for optimal efficiency on paracord, so that both blades are set up for cutting shroud lines.
I got a sharp 40 degree edge using my Spyderco Sharpmaker with diamond rods, which left an aggressive, rough finish on the edge. When cutting paracord, I feel the blade dragging a little. I am wondering if another sharpening session with the coarse (gray) ceramic rods would be best, or even if I should go all the way and produce a polished edge with the white rods.
I know the solution is to keep putting more polished edges on it until I reach the point of diminishing returns, but I figured someone here already knows the best edge for paracord.
Any suggestions will be appreciated!
