I know. I just forget at times. They are several years old so I'm cool with it. When I got my grinder I was working 80 hour weeks and wasn't worried about cost and burned up a few K worth if belts and steel. When I learned to weld you just burned as much wire or rod as you can and I kinda treated knife making the same way and a few beers in at 4 in the morning you don't make great decisions. All of my wheels took a beating. I learned something from it so I guess it's all good. Now I just have to pay for all of that "practice". It's on me. I was just looking for some good wheels to replace them with. I haven't had a chance to try anything else so I wasn't sure sure if there was much difference between small wheels. Someday I need to get at least one really nice large wheel.Remember that you need to slow the grinder down with small wheels. The ratio of a 5" drive wheel to a 1" wheel is a five fold increase in motor speed. Small wheels are not needed, or intended, to run at 8500 RPM or 17,000 RPM ( depending on the drive motor).
Bearing you use in USA should be in dimension close to 608 bearing / 8 x 22 x 7 mm / Max . speed for that size bearing is about 33.000 RPM .So how you come to that numbers that small bearings are not intended to run 8500 RPM ??? Did you ever try to use quality bearing in C3 or C4 tolerance which is wise to use in application like this ?Remember that you need to slow the grinder down with small wheels. The ratio of a 5" drive wheel to a 1" wheel is a five fold increase in motor speed. Small wheels are not needed, or intended, to run at 8500 RPM or 17,000 RPM ( depending on the drive motor).
cold start up application my cause the balls to heat up quickly, the heat needs to go somewhere. Some of the heat gets passed through the outer race to the housing and the inner race to the shaft, this causes expansion which closes up the clearance in the bearing. If you did not allow for this clearance the bearing would not have room for expansion and lead to bearing failure.
arbour press or bench vise plus proper spacers to press them on.Has anyone here replaced the bearings on Beaumont small wheels? I have the extra bearings, but I'm not sure about the best way to go about it.
If I just get KMG wheels that drop in I'm not missing out on anything right? That's more or less what I was looking for. I am more concerned about the wheel than the bearings. Bearings might affect the overall cost and might be a pain in the butt if they go out but they aren't the part that is actually doing the work. Whatever happens to the bearings is on me.Yes, they are rated for 33,000 RPM. However, that is a no-load rating.
The extreme load and poor heat conduction of a small wheel setup on a grinder can burn out a small bearing in a relatively short time.
Case in point is the bearings on a Beaumont rotary platen. They last a year at most under normal use and only moderate speeds. It is the load that kills them. Back the tension off the belt a tad and they will last a bit longer.
i tried to look that up for you (yes it looks like he uses KMG wheels (if i remember correctly) Brett Matthews says it on his web site of Esteem GrindersIf I just get KMG wheels that drop in I'm not missing out on anything right? That's more or less what I was looking for. I am more concerned about the wheel than the bearings. Bearings might affect the overall cost and might be a pain in the butt if they go out but they aren't the part that is actually doing the work. Whatever happens to the bearings is on me.
