Nimravus Nut said:Both steels are not intended for making prybars, but if you really insist on doing that, I believe it would be 154cm and you definitely would not want it to be tempered over 58HRC, or I will guarantee you it will snap like glass after you bend the blade past 30 degrees. I know because I tried it!![]()
I have a BM Nimravus 1/8" thick blade 154cm (tempered between 59-60Hrc), I was bored one day and I just wanted to see how far I could go with the knife if my life depended on it. I placed about 1/4" of the blade in a vise, and glued a protractor and stuck a 3 foot bar on the handle.......
10 degrees, blade returned to true.
20 degrees, blade returned to true.
25 degrees, blade did not return to true, about a 2-3 degree plastic deformation.
30 degrees......31......32......snap!![]()
I reprofiled it and it is serviceable again. I still kept the 1/4" blade tip to view it under a microscope. compare it with ats-34, the grain size of 154cm is smaller, therefore it is better than the japanese stuff.
Oh yeah.... did i mention I did it to both of my Nims.... one in ats-34 and of course one in 154cm. I also have a sample of Aus-8 and the grain size is the same as ats-34.![]()
Blop said:And there is no chance to repeat this with a M2 version?
You have sacrificed your knifes for the sake of enlightementD ). Thank you!:thumbup:
Result: If your knife starts bending, stop prying. Do we had to break so many knifes to learn that?![]()
