Best tongs for heat treating
Stromberg Knives
strombergknives.com
I've been heat treating O1 coupons this morning, trying to calibrate my process.
I've noticed my coupons get different hardness depending on how far inside my oven I put the steel. Initially I put the steel just inside the oven (it's a 24 inch Paragon) and the end toward the door was a lot softer than the other side.
It seem pretty obvious that I should put my blade/coupon closer to the TC, which means more to the middle/end of the oven. But how do I reach my blade with a sufficient grip for a fast quench?
What kind of tongs do you guys use? The opening of my oven isn't huge, so they cannot be too clumsy.
You could drill a hole, pass some sturdy wire through it and use your regular tongs to grab the wire...
I love thoes tongs, thoes where my first set and I use them all the time.
I bought several pairs listed as different sizes from Tracy, at USA Knifemaker, and they were all actually the same size when I got them--he says right on their website to not be afraid to adjust them to your needs-so I did just that--hit em with a torch til they were cherry red at the spot I wanted and bent them to suit me--they needed to be able to pick up damn thin stock for my needs---they seem to be pretty basic solid tools, and I anticipate them lasting a really long time--very reasonable priced by them also.
I make long one for me from ordinary pliers. Squeeze pliers in the vise with close jaw .With angle grinder cut where is the red line . Repeat if it is not enough / take pliers from vise and close jaw again and put back in vise / Weld extensions to handle ....... Of course if shape of this pliers fit to you ...
