Best way sharpening my JR Case sodbuster?
What will the best method be, without harming the blades geometry? I have a Japanese water stone and an old std. dry stone.
A friend proudly showed me his and I noticed that the poor JR who went already through some sharpening, have had lost the nice original blade geometry and looks now like a dagger…
Thanks.
If you only want to sharpen a sodbuster without complication I'll recommend you this video https://youtu.be/SEMLu8e34ck by jackknife
From there you can go as deep as you like down the rabbit hole, diferent stones, level of finish, etc. from most of us in this sub forum in one moment or another it became a hobby in itself and a quest for the sharpest edge possible.
A good deal of information is in the stickies at the top too.
Mateo
What lutejones linked is a great introductory video on microbeveling and/or "steeling"/honing/burnishing, by using high angle ( 20-30 degrees per side ), doing that will straighten any rolls , and also sharpen the apex, basically you'll see results real fast, but after a few sharpenings,, you'll have to do more
So start with instinctive sharpening, try it at least three times, before watching a second video.
This would be the follow up video (actually video after that), try it with your std. dry stone (I just bought another one at dollar tree the other day )
basic sharpening, raise a tiny burr, cut it off at elevated angle, shave how to sharpen a knife - Joe Calton
Good follow ups
Similar method (three step ) with a one dollar stone ? Cheap sharpening stone - does it work? - stefanwolf88
Extreme low grit sharpening : clay brick - Cliff Stamp
Thats almost all the secrets of sharpening freehand right there, easily get to shaving sharp with that info, and if you use a light touch, whittle hairs.
After you've sharpened a dozen times, watch the videos again, ... a lot of info you won't really appreciate until you try sharpening, don't watch too many videos before practicing
To keep from changing the outline/profile, just follow the curve , pivot/rotate the blade to keep the edge at right angle(90 degrees) to the abrasive and end with the tip on the abrasive, don't come off the stone
rabbit holes of good info/videos/links more links/talk about the same basics
The Seven Secrets of Sharpening
1363264-Best-correct-way-to-inexpensively-sharpen-a-pocket-knife
