I have always silver soldered. Since coming to the forums I have seen everything from soldering to using liquid steel or epoxy. I still think silver soldering is best. You can solder and pin guards if you don't trust the solder.
When you do solder a guard on, put the blade in a vise tang down and put the flame on the tang about 1 1/4" below the guard. That way, the heat moves up the tang and the blade won't get too hot. Also, with tang down, the flux, which is actually acid, won't run down the blade and etch it. This happened to me for a while till I read Texas Knifemaker's Supply catalog. It has tips on soldering guards.
To hold the guard in place while soldering, you can either clamp it in place or take a punch and make several dings in the guard near and towards the tang. just make sure it will stay put before you start heating it up. Take care! Michael
"Always think of your fellow knife makers as partners in the search for the perfect blade, not as people trying to compete with you and your work!"
