- Dec 2, 1999
I have two sharpening systems, one is an older diamond clamp/angle system, like Gatco but with narrow stones, I also have a Spyderco sharpmaker.
I can do the magic marker trick, I want to bring the edge angle down (it's a sebenza) so it will cut like a ZDP-189 Caly.
Should I just do Spyderco at 30 degrees all the way to start, giving me 15 per side? Or should I use the angle system (which is a bit sloppy in holding the angle) which I think goes down to 10 degrees per side. But I only have the "fine" diamond which I think is around 600 grit.
Also if I put Flitz on leather for a strop, will it act similarly to the chromium oxide green which I don't have?
Thanks
Thanks
