Opening it an trying to wiggle the blade won't ruin anything if it's a well made knife.
I was just unsure how much pressure to use/how much "wiggle" there should be, because I can make any blade wiggle if I wanted.
What is the knife in question?
Some linerless zytel SOG's and even some spydercos with thin liners will have flex in the handle that can be mistaken for bladeplay. I am personally not satisfied unless there is absolutely zero perceivable play between the blade and the handle
I doubt you can make "any" blade wiggle by hand force, no offense. Unless you try to on some $5 gas station knives, no knife worth buying will develop blade play from hand pressure alone.
I crank on the tip and use as much force as I can with just two fingers. I can get play in 99% of folders like this either due to some sort of flex or actual movement in the pivot. The only folders I owned that passed this test were the Sebenza and Umnumzaan. Blade play only bothers me if I adjust the pivot and still find it when cranking on the blade as close to the pivot as I can. That tells me its a real pos with crap tolerances. This is purely my opinion and I could care less what other people think. I'm picky about my folders and I have compulsive tendencies with them. Of course you have to consider price and adjust your expectations accordingly. I dont care if a sub $100 folder has a tiny bit of play.
You could not detect any blade play in a few of my folders. I am well above average adult male strength and I try to break the tip of the blade off when I test if I know the knife can take it.![]()
That's what I'm talking about, I mean it's barely detectable but it's there. If you say you've seen it on 99% of knives aside from the CR knives then that mirrors my findings as well and it must be fairly normal. It's not like they'd be wiggling around under normal usage, so I guess I shouldn't care much. It's so little that I can barely tell if it's the blade moving or the entire knife moving in my hand as I pull and tug, if that helps explain it any better. Probably just my paranoia.
