I posted this over at SOSAK -
Refurishing SAKs
I received a number of used Wengers recently, and am starting to clean-up and refurbish them. Since Victorinox and Wengers are similar in the use of polished red cellidor/plastic handles as well as stainless steel tools and aluminum liners - the refurbishing is basically the same.
The cleaning is simply using warm soapy water and a toothbrush to clean out as much debris/dirt as possible.
Put a drop of diswashing detergent into the opened handles and rinse out with hot water from the tap at full pressure.
Work the blades/tools in the soapy water to clean out the pivots. Make sure to brush the pivot/tang areas as thoroughly as possible.
Rinse the fully opened SAK with hot water and shake hard to expel as much water as possible - but be careful since the blades are open - not to stab or cut oneself. Use a towel to wipe off any remaining water. Allow to air dry.
Spray WD-40 into the open handles and use a cotton bud/swab to reach in and clean. Wipe dry then lub the joints lightly (I use 3 in 1) and work the blades/tools.
Now on to the handles - these are bound to be scratched marred for any well used SAK - since those polished cellidor/plastic mark easily.
If the marring is light a quick polish with some good car polish would improve things a lot.
If the handles are (more likely) pretty scratched up, use something with more cutting power/abrasive like (car) polishing compound or since I can't find mine - I just used some metal polish that I had handy.
The Wenger Journeyman was well used and in fair to poor condition - even the metal polish didn't quite do it for me - so I needed to use something even more abrasive/cutting like rubbing compound - again I didn't have any handy - so I just used the green scouring pad backed by sponge that I had in the kitchen (eg: Scotch-Brite) - I used it wet with soapy water and scoured the handles to an even matte finish - graduated back to the metal polish to get the handles to look reasonably shiney - then finished off with car polish to get a high shine.
Before & After, and compared with new condition
Both the knife blades showed some harder work/abuse in that they had kinks in the edge - I did not try to unkink them - just worked on them on a hone to eliminate the kinks from the edge - so the blades still show the evidence of kinking but at least have reasonable working edges -
I find the backsprings on the Wengers tend to be softer/easier to close than Victorinox and this Journeyman's backspring has worn/weakened - so that I can induce some wobble when sharpening the blades on the hone.
Vincent
http://UnknownVincent.cjb.Net
http://UnknownVT.cjb.Net
