Start with a wire brush. Sandblasting also works to clean off the surface rust.
If the rust on the surface is really bad, after wire brushing all you can off, use a phosphoric acid based rust remover. Apply it and wait half an hour, wash off, wire brush, repeat as needed. When done, start the kerosene soak and method below.
Soak in kerosene for a few weeks. A wall-papering tray works great for long handled things like tongs. Or, use a quench tank full of kerosene. A PVC tube will also work with kerosene. Wire brush to remove what rust you can. Try to get them to break free so they will open and close. Sometimes striking the rivet and from the side with a hammer will free up a stuck joint. Use rust buster or penetrating oil if needed.
If still stuck, drill out the rivet, clean up the joint with a file, and put in a new rivet.
On tools where you can't put in a new rivet and the joints are still stuck or very stiff after the kerosene treatment and penetrating oil:
Use a torch and heat up the joint area. Work the jaws hard while hot. If they still won't budge, heat again to around 400-500F and dunk in the quench tank. Pull out and work hard. Repeat as needed to break down the binding surfaces.
When freed up, oil the jaws well with penetrating oil and give a the rest good coating of WD-40 . Work them every few days to get back into shape. Reapply the penetrating oil after every use.
