- Apr 3, 2013
I have tried a lot of different lubes and grease's to try and find a lube that works really well,what I have found is that grease such as Super Lube is about the best grease you can use for not being thick that being said however I find that grease makes the action sticky and the blade does not flip open really fast.
I have also tried many different oil's as well and found that Benchmade BlueLube is the best oil out there however it runs off and then the bearings are running dry.
What I have found that works the best and it helps the blade flip open really fast and free is to use 1 drop of BlueLube on each bearing then put some SuperLube grease on the bearings,I find the grease holds the BlueLube in place nd the BlueLube in turn makes the grease more slippery.
