My question is just this:
How do you make sure the apex of the edge is reasonably centered?
What's a "matching" width? Just curious, since I figure a drill bit tip is a drill bit tip, no matter how wide the bit is. Do you use a detailed ruler to know where to mark or do you just eyeball it? I'm also guessing that after the initial grind and heat treatment it should be thin enough to just grind the edge bevel on without anymore fidgeting about the edge centering? I've got a piece of 1080 and D2 steel that I've long neglected for a year but am thinking about using at some point.You can scribe a line with a matching width drill bit. At least that's how I've seen it done.
Ah okay, that makes sense now.What he means by that is if your blank is say, 3/16" thick, a 3/16" bit would have a tip 3/32" from either side. If you lay down your blank on a flat surface, you can also lay the drill bit beside it and scribe lines by scraping the tip against the blank. You'd want to do this from both sides though, in case the tip isn't exactly in the center of your bit.
Paint blank edge with Dykem or other steel marker, then use a divider to draw center line. This way you can clearly see the apex line as you grind toward it.My question is just this:
