I just stripped a screw on a Boker Plus knife(What a surprise LOL) and would like to know if anyone has a way to get them out short of sending it back to Boker ?
Any help would be appreciated.
I honestly didn't think of it. SorryDid you use the Search function before posting?
https://bladeforums.com/threads/stripped-screw-no-problem.1543322/
Phillips recess. on the pocket clipWhat is stripped? The thread? The TORX recess? The hex recess? The Phillips recess?
Must be a glitch. I only posted once.why two threads on this subject 20 minutes or so apart posted? done on purpose for some reason or some weird software glitch?
Phillips recess. on the pocket clipWhat part is stripped?
thanksPictures always help in such situations as well, there are a number of techniques to remove screws that don't want to move. Cutting a slot to use a different tool to get it out, drill it out and cut a new thread, use a hammer to smash in a different tool (for example using a torx to get an allen screw out) there are more and less delicate ways.
If the head is protruding, I would grind a slot with a Dremel tool using a ceramic disc. I would heat the screw with a soldering iron in case there is some LocTite present. Then I would turn the screw out with a closely fitted slotted bit.Phillips recess. on the pocket clip
thanks
I posted this before I spoke to you. After our agreement I decided that I don't need it. Got to clean some out first. I will be listing some good ones here this week.Are you talking about the Exskelibur?
Just leave it man, there is no need to moge the pocket clip anyway. As long as it is secured to tip up position I don’t see why you would have to move it. Also since the screw is countersunk most these methods won’t work anyway.
You don’t have to remove the clipnto disassemble.
