Best way to sand and finish Polyethylene
Linus Knives
Moderator
I'm workin on rehandling this case knife but my sandpaper doesn't seem to want to polish this up. Any ideas? It looks about like this now and I want it to look like the second picture...
I have done more shaping to the handle but it doesn't hog easily at all and only does with a new 36 grit belt.
Im using a block of plastic (Polyethylene) from amazon which is about the same as what's in the picture.
PE is a thermoplastic, so you can heat it up after sanding and buffing, if you're after a shiny surface. I'd probably go to roughly 1200 grit before buffing with a fine cut compound, but it works just fine with a coarser grit, if you're patient on the wheel. I usually overshoot my grits, so I can keep my pins and/or spine flush on the wheel.
Edit: if you still have some of the material left, it's always a good idea to check on a separate piece what sort of finish would look best for your application.
