I am asking this because i have a tops bob field-craft knife with a modified scandi grind. At this current time i am reading reviews and forums for the best sharpener for scandi grinds. So i have it narrowed down to three different ones. The first one is doing it free hand with stones, i kinda suck at freehand. The second one is the worksharp belt grinder, only thing about this belt grinder is it puts a convex edge on everything. I also know you can blunt your blade tip if not done correctly. The last one which is the wicked edge gen III, this one is expensive but can handle a variety of different blades. The tops bob is almost looks like a modified v flat grind to a convex at 11-12 degrees finale edge, from what tops told me. I assume they mean 11-12 degrees on both sides for a total of 22-24, unless they mean 5.5-6 degrees on each side. I guess my question is what is the best way to sharpen a scandi grind. I am just torn between sharpeners, they all have pros and cons. for instance the work sharp won't give an exact same degree on both sides of a blade. I will be getting different blades with different edges, like convex. I will most likely have a lot of scandi and convex edges since all my knives are for bushcraft/survival and outdoor stuff. SIGH!!!!!!!!!!!!!!!!!!
