There couldn't be any controlled spine whacks?There are videos of Benchmades being testing by some kind of hydraulic machine in a controlled environment. The test shows how much weight it takes to make it fail. That is the only real way to test a lock's strength, you need a controlled environment with consistent procedures to get consistent results. Any other test such as spine whacks are useless.
[video=youtube;6ZwwLWQk664]http://www.youtube.com/watch?v=6ZwwLWQk664[/video]
Just drop a hammer on your knives always from the same height, same weight and same distance to your pivots. Increase the height until the first knife fails, then the second and so on. This way you can see which one of your test subjects is the strongest.
Use masking tape or some rubber hammer to not scratch the babies
Even if its possible I wouldn't do it. While its nice to know what my knives can take, I imagine stressing the lock that way can lead to permanent damage.
The best way to test a folder lock is to open it and then try to close it with your hands without unlocking it yourself. If you can't close it with your hands when its locked I can't think of a single way I can properly use a knife that can close it.
This is also what I do, and I do this on every folder I get before I carry it. Open the knife and make sure it's locked. Keep your fingers out of the blade path and hold the handle in one hand. Put steady pressure on the blade spine (I don't whack mine on anything) with the other hand until you're satisfied that you've exceeded any pressure the knife will likely encounter. I've only had two liner locks fail to stay open. The lock bar on both of these ran right back across the tang under very little pressure and unlocked the knife blade. No other lock type has ever failed on me.
1) If you are concerned about lock strength, you should be using a fixed blade. Its simple. If you ever think "This might make my lock fail." you shouldn't be using a folder at that time.
Or....2) Get a slipjoint, learn to use it, and you don't have to worry about lock strength.
