Ig I was thinking the lighter stuff would work better to dissipate the
heat from the Blade faster, as in heating and making the oil more fluent, helps that,
OK guys a debate your thoughts on this stuff....
the thinking that heating oil to dissipate heat faster sounds funny
but can thick oil , for a lack of the right words, insulate the heat, keeping the over heated oil at or just away (by the boiling action) from the blade to long., ..say for the 1095 steel ... that viscously thing maybe?
using water is great for a fast quench
because it is so fluent but some guys leave it in the water way to long
and don't get it out soon enough once your past the noise just right. need to be Fast...or crack goes the weee opps sorry wrong song..
with veggie oil you need a lot of it for the big blades because it ( the oil)heats so fast
and can keep you from getting below the nose fast enough, that insulating effect again.
now if you want the best of two worlds down the middle,, short of
salt baths, use a brine of salt, anyone can mess with that..
just keep track of the amount of salt to water ratio and the temp u use.
test test test..
just my opinions here, thoughts and I'm only talking about Carbons.
