Better clip for Code 4?
I really like this knife and would like to carry it, but the clip refuses to go over the seam on my jeans.
I removed the clip yesterday to try and tweak it, but it's so stiff I couldn't bend it.
Is there a clip I can buy that works better?
Thank you!
Not that i'm aware of mate. I took my clip off, put it in a vice with some cloth around it to avoid scratches and gently bent it a little until it was the right tension. You can do this by tapping it with a hammer gently in the right direction or using some vice grips. Now it works great on the pants, strong enough to hold it in but not so it's giving me a wedgie every time i pull it out my pocket. Give it a shot, but go slow, you don't want to over bend, bit by bit and you'll get the sweet spot. But I will say some aftermarket clips for CS knives would be great, can't imagine it'd be that hard to make.
I ended up using a piece of looped paracord to pull the pocket-clip away from the body of the knife about an 8th of an inch.
It worked!
The clip now slides over the seam of my jeans' pockets and holds securely.
Thank you!
I went through the same dilema. I found this
https://www.etsy.com/listing/211045275/titanium-pocket-clip-for-cold-steel
and it has taken the knife to a whole new level. You can get it in different finishes. Goes in and out of the pocket and carries perfect. Well worth the money.
Sent from my iPad using Tapatalk Pro
