Better edge burnishing
I have posted earlier this type of sheat, only this time I used better leather I think (which is already dyed). Still trying to get the edge more shining but I think that it would be hard without belt sander. ( I used dremel but it always seems like there is a small tiny crack which I cannot burnish Criticism welcome.
If you're talking about the bottom edge where it folds under, you need to burnish that before you assemble and sew it.
In the middle layer you can see one "line" which I couldnt reach with burnisher. When I sand that with dremmel it looked like is flat, but after burnishing that line appeared.
use the cone end pointier par of a wood slicker and stick on top of the crack , Before so , use a wet sponge and dampen the leather. Mine turns almost into a wax finish once i'm done and no cracks. Even on a stacked leather sheath
A couple of thoughts Macan. Are you tapping the glued joint with a hammer to help bind? What glue are you using? Many contact cements are further activated by pressure which is why the tapping helps. The intial thing that jumps out at me would be to say more sanding. Maybe the dremel isn't the right tool. I do use one but only for tight inside curves that I can't get with anything else. maybe by hand using a block?
Thank you guys for answers. I didnt tap with hammer, I will try that . I used Saratoga neostick (italian glue) wich should be good. Probably for my problem the right thing to do is sanding with block
A lot of edge finishing problems start with your selection of leather for both the body of the sheath and the welt. If you use really top grade tight grain leather to start with for both the body AND the welt you will minimize your problems right from the start. If you have good leather for top and bottom and a softer belly leather welt, I guarantee no amount of sanding or burnishing is going to produce a prize winning finish. The softer leather will actually move with the sanding device and material will just lay over and not be removed at the same rate leaving a high or low spot in the center of the three layers. If you have chosen less than prime leather for the body of the sheath, and for the welt, (saving money and /or not wasting leather) you have cost yourself the heavy price of a much less than perfect finish job, and since it's three layers, you've tripled your problem.
It is far cheaper in the long run to use top quality leather throughout the piece and have something that you are really proud of……..than it is to do it over because of bad results or worse yet, reflecting on your ability or apparent lack thereof.
Three or more layers of really good tight leather will produce a nice consistent finished edge IF you have performed all the steps necessary to get there.
Choosing good tight flesh side leather is more important than anything I know for obtaining beautifully finished edges.
Paul
Thank you Paul, now I got the whole picture. This letther is nice lookin' , but it could be stiffer. Altough, when you cut this leather it comes shiny just from that.Thanks again.
