Do you mean 5160 differentially heat treated vs 5160 through hardened?
Differentially heat treated blades can take more abuse than through hardened
define abuse. if you mean poor technique or improper target cutting your statement is incorrect.
this is a good explanation
http://swordforum.com/forums/showpost.php?p=870299&postcount=5
Zombie hordes? That means multiple targets. And that means you'd be better off with something light and quick. Otherwise you will become more easily fatigued then it's game over.
True, I'm not exactly Conan and running and cutting would probably be the norm.
Wolf_1989 -- well if the zombies ever do come, you are probably going to want to switch your thinking around. IF zombies act and have the abilities we all think they will, then sound is your biggest enemy. so a sword is going to be what you want and a gun for only a last resort. also ammo will run out fast in such a situation as people will hoard it or it will just simply run out.
so IMO you are going to want something like a wakizashi as your main sword, (as it is smaller and can be yielded faster and in tight spaces.) a tanto for the same reason and as a back-up. also a katana for when you are in those wide open spots. just like the samurai used to use them for. always have that gun handy! but you fire a shot, and the hoard comes running after you!
as as for not wanting a melee weapon cause of posibly getting bit, PVC makes good cheep armor or even football or hockey gear. even leather. anythiing that can keep a bit getting through. they didn't call the Marines "Leather Necks" for nothing!
