- Apr 9, 2019
I suspect it is better than M390 for edge stability, toughness and maybe wear resistance due to higher hardness (64hrc). What is everyone's experience with SRS-15?
You mean M398? https://knifesteelnerds.com/2019/05/06/bohler-m398/I'm personally waiting for m390+1. That should be amazing.
Looks like ZDP-189 with a vanadium chaser:
Why would you say it's better than M390, just because it might be tougher? M390 isn't a favored steel just because of its toughness.
The formula looks like S30V with some vanadium replaced with tungsten. I'm a bit skeptical of the 64HRC value Zknives is quoting:
- Vanadium carbides are harder than tungsten carbides; S30V has more vanadium
- S30V maxes at 64HRC before tempering, per Crucible's data sheet. That would probably make it quite brittle at that hardness. Not sure how SRS-15 would achieve that without sacrificing a lot of toughness
Per Larrin (link) the nitrogen addition should help increase the potential hardness of S30V, if you hold everything else equal. Which further leads me to think there's something wrong with the Zknives listing. Probably the formula, I'd guess.I'm not metallurgy expert, but I was going to talk about the distinct lack of vanadium in SRS-15 but you sort of beat me to it. Vanadium seems to be a wonder element when it comes to cutlery alloys, probably due to the ridiculously hard Vanadium Carbides. Can we also talk about the trace of nitrogen in S30V?
Yes basically the same except for that tiny addition of 7% vanadium.Looks like ZDP-189 with a vanadium chaser:
http://zknives.com/knives/steels/steelgraph.php?nm=m398,ZDP-189&ni=,410&hrn=1&gm=0
Glass cannon?
No, It makes a good knife, I own a SRS -15 240mm Akifusa PM Migaki in this steel, San Mai at 64rcLooks like ZDP-189 with a vanadium chaser:
Glass cannon?
Nooooo, m390+1 it's like m390, but +1 better. Sort of like m391, but cooler than that.
