I'm attempting to sharpen a new knife and it just doesn't seem right. I removed the factory bevel and have attempted to put an even bevel on it, but I just feel like I'm doing something wrong. I'll start by explaining my method. I'm using a Smith's tri-hone, and since I am new to sharpening I have been using the guide which sets the bevel at 23 degrees. I am pushing the blade across the stone as if trying to scrape off the top layer of the stone and pulling the knife butt to tip as I go across. I used the synthetic stone to remove the factory bevel and seemed to have the bevel relatively even, however as I progress to the medium for sharpening and fine stone for polishing a few issues become more noticeable.
Towards the base of the knife the bevel seems to be shallower, and as the knife curves there is a line where the scratch pattern abruptly changes. Also, I am concerned with how thin the bevel on the knife appears. Looking at a side view a factory knife the bevel is very visible and can even be a few mm's wide. My bevel is very difficult to see and is not near as wide as a factory bevel. The exception to this is at the tip where the bevel goes deeper into the side of the knife than it does anywhere else.
In addition to general advice I have a few specific questions.
1: is 23 degrees a good choice for an EDC knife?
2: Is it ok to pull the bevel backwards across the stones instead of pushing the bevel across them? Does this result in a fundamentally different type of bevel?
3: Is the narrow bevel anything to be concerned with?
4: Why is the bevel wider at the tip and curve than at the straight portion of the blade?
