I have run into a bit of a problem, I got myself a sharpmaker a few months back and figured it would be a great way to touch up my knives and keep them sharp but I've run into a problem with quite a few of my knives. The bevels are not even, it's very consistent (up to the point that I am starting to question whether my sharpmaker is aligned properly or not) on a lot of my knives the bevel is quite uneven and I can't seem to get rid of it. In the most extreme case (my gayle bradley) even on the 15 degree setting to do a back bevel I will only barely hit the edge (as if my bevel is lower than 15*) on one side and sharpen perfectly fine on the other. I've found this from doing the sharpie test and it does vary from knife to knife how much it will be but I only have 2 knives that are actually even on the grind (511 and tenacious). I'm sure I'm using it properly, I'm not tilting the knife one way or another so it's not that I'm not getting the angle properly, it's straight up and down.
So, I'm looking to find a way that I'll be able to fix this, I've been looking at some other options that will be a little more effective of being able to rebevel my knives evenly and could use some suggestions on which would be the easiest/best for this/least likely to have my ruin my knives while trying to rebevel.
Looked into the paper wheels because to me there's a big attraction to the power tool to be able to grind my bevels even, I figure I'll be able to take off a decent bit of metal and so many people rave about them, BUT I'm also kind of worried about them because I figure they're most likely the easiest of my options for me to be able to destroy my knives on and I don't really have space or a workshop to put them in.
Second option I looked at was the edge pro apex, I figured the exact angles I can get on this and wide range of sharpening stones will be able to help a lot on getting an even edge on my knives, BUT I read just recently that someone ruined their knife trying to fix an uneven bevel on the edge pro because to get the angle down to where it needed took too much metal off the knife or something, also this seems to be the most expensive option by far.
Third option that I've seen around here and intrigues me is the workshop, that little tiny belt grinder. This appeals to me because it's fairly cheap, and puts a convex edge on knives BUT if I have convexed edges, while I do like them I wont really have as easy of a time touching them up on the sharpmaker between sharpenings and I'm not sure what range or availability of different grades of belts I can get for this device.
Any other options or suggestions would be helpful, yes I know I should learn to sharpen freehand on a sharpening stone, I was doing that when I was a little kid in cub scouts and after all that time... I am still very unskilled.
