Beware?
Is there anything I need to be aware of regarding the Dynasty Forge Musha Series Ko-Katana? I know there was an issue with the wood used for the handles and to make sure it was made AFTER that was resolved, but other than that, anything I should know? I don't just mean about manufacturing oops's, I mean the sword itself. Corrosion, durability, balance, anything? I'm considering one of these and just need to know if there is a reason to kick it off the list. Thanks in advance for whatever insight y'all can provide.
I have one that holds up ok and is pretty good for what you're spending. I did have to return the first one I bought because the wrap job was faulty in a bad way, but they sent me a new one no problem.
Am I hearing you wrong, or are you somewhat underwhelmed by it? You just sound like you don't think too much of it, no?
The blade seems a little meaty, does it handle like it is overweight?
I appreciate your input, I've never seen one in person, so it is very helpful
They are pretty light if you get the one with bohi fullered. Its an ok sword and if you don't want to spend a whole lot then this is a good option. i think mine handles great.
I appreciate the information, thank you.
How durable is it? I don't expect anything (other Bussekin excluded) to be on par with my Rodent Waking, but I am concerned about how easily it will take a set. I have a lower quality katana and, in an effort to cut something I probably shouldn't have, I put a slight warp in the blade. It bothered me enough to go buy the Rodent which is almost indestructible. I really want something I don't have to worry about, too much. Is it something that can handle a little bit of punishment? Or will it end up tweaked the first time I try to cut down a sappling?
I think if you try to take down a sapling there is a very good chance it will take a set. i have not tried that with mine and would not recommend it. If you want a katana like object I suggest you get Chris Palmer of scorpion swords to make you one.
I would advise against Scorpion Swords. I find there designs, materials, and worksmanship to fall short of their prices. $200 for a machete~? No thanks. The fit and finish is not so good, and resale is beyond terrible. There's a guy on another forum that couldn't unload a pair of Scorpion swords even at lower then 50%. Sorry just don't see the value.
As far as Dynasty Forge goes, they are fairly good manufacturer. As you mentioned already make sure it is not one with tsuka core issues. As far as durability, they are very durable and heat treatment is fairly consistent and good. Should be more then fine taking on traditional tatami omote mats.
Have you handled one of his pieces before? I would also note that his machetes are not really machetes as they are 3/16" thick and would wear your arm out in no time flat.
I did recommended it as something to hack on saplings with :); and the gentleman's golok he recently posted on the for sale forums is a significant improvement over his earlier work.
