M4Super90
Biochemical Superfreak
- Aug 26, 2008
OK, so when I said 5” knives in the previous post I wasn’t telling the whole truth. Here’s why. We all know that since each knife is handmade, there are going to be subtle differences from knife to knife even between the same model (teaser alert for Part 3!). Handles will be thicker or thinner, grinds are different, and of course blade thickness all make each one unique.
Two weeks ago I received a shipment of models for comparison from Phil which included a Hunter, a Leuku, and a Runt. I was able to purchase a Woodsman from a forum member some time ago, and recently a new Camp Nessie and Duke. Of course, I take every opportunity to add a BC Senior when I can.
If you look on the Fiddleback webpage, you’ll notice the Bushcrafter, Nessmuck, Terrasaur, Kephart and Bushfinger are all in the 4” section. So are the Camp Nessie and Hunter. The Duke and the Woodsman are in the 5” Section. The Leuku and the BC Senior are in not currently listed. However, the Leuku was released on 03/28/14 and described as “This knife is a larger version of the Recluse. I’m calling it the Fiddleback Leukko. The blade on this knife is 5” long and the handle is 4.5” long” in the original listing (Not sure when it changed to Leuku). The BC Senior has been described on 07/12/13 as “BACK FROM THE DEAD!!! The Bushcrafter Sr – this is a Bushcrafter with a 5” blade”.
“Feel” is a very subjective way to evaluate. I mention this because many times I have read the specs, I know the exact dimensions, but it doesn’t “feel” like I expected (for example, my first Recluse). What I noticed is that if you sort these knives by the way they feel in the hand relative to other 4” knives, you can make two piles easily. What is interesting is that they do not sort the same way as they are grouped on the FF website (blade size). To test this I performed a blinded test on my wife and on a friend with 10 Fiddleback knives (See below: six 4” knives and four 5” knives).
The result was the same both times. It was also the same as the way I was sorting them. The Hunter and the Camp Nessie end up with the 5” knives. The Leuku ends up with the 4 inch knives. That might be a consequence of this Leuku being so light. However, dimension-wise that handle seems more like a 4” (compare to the Kephart in the photo above). So that grouping is the way I am going to compare them for the large knife review. Here's the way they sort:
I am throwing the Leuku in for the sake of the review, as it really is a 5” blade. That group consists of:
Duke
Woodsman
Leuku
Bushcrafter Senior
Hunter
Camp Nessie
The specs on each knife are:
Duke (purchased from a forum member) Ironwood burl over lime and black, Predator pinout. Convex on 3/16", SFT Tang, heavily spalted 01.
Woodsman (purchased from a forum member) Sapphire burlap from Shadetree over black g10 with a white g10 pinstripe, SFT Tang, Convex on 5/32”, heavily spalted 01 steel.
Leuku (on loan from Phil) Emerald burlap over black liners with a white pinstripe, Tapered Tang, Convex on 5/32”, Fiddletextured 01.
Hunter (on loan from Phil) 2014 0808 23 – Hunter with black canvas micarta bolsters over Emerald burlap with Trinity pinout, SFT Tang, convex on 5/32”, spalted 01 steel.
Camp Nessie (purchased from BladeCo. around 09/03/14) - Black burlap over black with yellow liners 3/16", spalted 01 steel.
Bushcrafter Senior (received in trade from a forum member, 2014 0718 18) – Ironwood burl over black g10 with white pinstripes, SFT Tang, convex on 5/32”, spalted 01 steel.
Obligatory photos:
Duke
Woodsman
Leuku
Bushcrafter Senior
Hunter
Camp Nessie
Size comparison. You'll notice that all 4" knives are not 4" and the same is true of the 5" group. As an example, there's not even 1/2" blade length difference between the 4" Hunter and 5" BC Sr., but there is over 3/4" difference between the BC Sr. and the Duke, which are both in the 5" category. Each knife has been lined up at the start of the cutting edge of the blade, using the Thurin method:
Some Mistwalker in-the-hand shots. My palm is right at 4" wide:
The weights are significantly different based on the handle material, the tang and grind height:
Duke 10.4 oz / 294 g
Camp Nessie 9.9 oz / 282 g
Woodsman 9.1 oz / 258 g
Hunter 8.0 0z / 227 g
Bushcrafter Senior 7.8 oz / 221 g
Leuku 5.7 oz / 162 g
I would not have expected a 4” to be near the top of the list, nor a 5” to be at the bottom. Obviously this has an effect on the balance point. The Comprehensivist method for determining balance point (this is more difficult to do than it looks, if you have not attempted it. I'm amazed Phil could get 4 BC all balanced at the same time. I tried to get all 6 together for a comparison shot and finally gave up):
General Impressions
It doesn’t take any stretch of the imagination to see why some of the 4” blades end up in the “larger” knife group. As you can see, the Duke and Woodsman handles are more similar in shape, length and circumference to the Hunter and Camp Nessie than the Bushcrafter Senior and Leuku. The longer grips that go through my hand are comfortable to me. I have always gravitated toward the Hiking Buddy/KE Bushie/Arete/BC handle as it feels great in my hand. The knives that do not have a rounded butt and a shorter grip seem to dig in with extended use, but this is not the case with the knives here. And that’s a good thing. The longer blade creates more leverage and applies more pressure during use. It makes sense that the heftier blade for heavier tasks is paired with a handle that extends past the palm and it works well. The BC Sr. solves this issue with the rounded butt.
The Hunter is a beefed up Bushfinger. If you like the ergonomics of the Bushfinger and want a larger knife, the Hunter is the one you want to try. I was keenly interested in the Hunter/Duke/Woodsman comparison. To be honest, it took me a while before I could pick them out by sight in the Fotoki pics if they were not all in the same photo. I’ve had the Woodsman in the field many times and while it does handy work around the camp, I couldn’t see myself skinning game easily with it, nor do I think that is the role it was intended to fill. But hey – I always imagine the “one knife” scenario and I think a 5/32 or 3/16 Hunter comes close. The additional belly on the blade speaks for itself. I am more impressed with the Hunter than I thought I would be.
That brings us to the Duke. The Duke would fill some heavier rolls than the Hunter. It is the heaviest knife of the bunch and really fills the hand. The mass detracts a little from lighter tasks I might want to perform. The Woodsman is a better slicer and the Camp Nessie a better prep knife for breaking down root vegetables. I like the Duke, but it is a bit of an in-between knife for me. The Duke just makes me want a Camp Knife or a Bishop. A 3/16” SFT bruiser. Go large or go home.
On the other side of the coin, the tapered Leuku is freakishly light. This is the feel that I was expecting with the first Recluse I bought. I REALLY like this knife. Actually, this is one instance where a larger knife feels smaller instead of the other way around. With the BC Sr., you still put it in the larger category even with the shorter grip. Not so with the Leuku. The BC Sr. and Leuku are the most agile due to weight and balance point. But agile is not always the best trait if you were to desire some heft when batoning thicker logs for the fire. Although, the Leuku did admirably well in the batoning test……
…. just a joke Phil.
My Camp Nessie is hefty. I love the blade profile and it is great prep knife. I would like to try a Camp Nessie in 5/32 with a tapered tang. I think that would quickly become a favorite. I don’t have anything bad to say about it. It is a chunk of a knife for a 4” blade. A bit of a bulldog in stature and can easily handle tasks much larger than you would think based on a spec sheet.
I really enjoyed handling and comparing each of these knives and I think each have their place. If you had to pick one it would be very tough choice. I don’t know if I could get this group down to one. The Hunter is a great all-round profile and would be an excellent general tasker. I could see myself skinning an elk with it. The BC Sr. feels much like all the other BCs I have and I love that handle. I can think of a lot of things to do with that extra inch of blade. The Leuku impressed me the most. I need one. Actually, Phil may need one. Possession is 9/10ths of the law, isn’t it? But since he is one of the most generous individuals I’ve met and made these reviews possible, I’ll probably send it back. Probably.
On the other hand, why narrow it down to only one? It’s not in our nature as knife lovers. I will freely admit, I continually think of unique use scenarios so I might learn and enjoy in the quest for the perfect knife for that role. After this comparison, I have a few more options to consider.
Duke
Woodsman
Leuku
Bushcrafter Senior
Hunter
Camp Nessie
Obligatory photos:
Duke
Woodsman
Leuku
Bushcrafter Senior
Hunter
Camp Nessie
General Impressions
