- Feb 18, 2006
I sent my 186 XLTI in for a BG-42. It came back in eight days which impressed me very much. I wonder if it will take another eight days to get the wooble out of the blade. The blade has plenty of side to side wobble and up and down wobble with poor lock up. Oh and has a nice rattle if you shake the knife.
The BG-42 blade has a bronze bushing which has an inner diameter way to large for the screw that is supposed hold it to the handle. The hole in the blade is to large for the original stainless bushing for the 186. So there must be a third correct bushing for this application which they did not bother to use.
Do you have to ask them to inspect the work that they do or is there an additional fee?
Well it's back from it's second trip to Buck. It has one improvement. The blade does not flex backwards when cutting. The same bronze bushing is still there so the blade screw cannot be tightened to much or the blade will not move. The bronze bushing which is pressed into the BG-42 needs to be thicker than the blade. It is obvious at this point that Buck does not have the correct bushing to hook up a BG-42 to a 186. I have tightened the screw just enough so the blade does not get pinched and added lock tite to the threads. The lock tite has to cure for 24 hours so I will no more tomorrow. This knife will no longer be carried for daily use. I don't think the bronze bushing will last long rubbing against the threads of the blade screw. The original blade bushing is stainless steel. I would think the bronze bushing would be best used on a 560 or 110.
I guess not enough 186's get sent in for blade swaps to warrant stocking the correct part.
