Bi-metal bandsaw
I was just looking at the bandsaw thread and the idea occurred to me that bi-metal bandsaw blades could make really nice knives. really hard edge and softer spine. Ive heard something about this a long time ago, but I cant remember what the consensus was. Is .063"(1/16") (the thickest I could find) too thin for even a short knife?, and is it really feasible to grind?
many fine pocket knives have 1/16" blades.
thin blades can certainly be just as handy as thick ones.
:thumbup:
Not at all too thin. They should make fine knife blades. Especially nice for fillet, paring, and steak knives. My local metal supply warehouse throws out two to three 14' x 1.25" blades per month. The teeth are usually gone or the blade simply snaps while cutting. Find one local and you could probably get them to save a couple dead blades for you.
what type of teeth would be easiest to get rid of? I'm thinking the smaller the better
Well, if you only want a small thin wharncliff blade of doubtful quality, I suppose you could do it.
The problems come from the degree of hardening, the shallow depth of hardening, and the degree of softness of the blade spine.
Another problem is you said,"Bi-metal band saw blades". Bi-metal blades have the teeth impulse hardened usually, and would not make good knife material. However, if you meant, "Power hacksaw blades", then that is often a usable material. These type of blades are often of a singular material, and fully hardened.
Many folks who have access to new and used power hacksaw blades select the ones made out of something like M4, grind them in the hardened condition (usually into fillet knives), and draw the temper back to a reasonable hardness.
Bi metals are made of two types of steel. The HSS teeth are welded on the relatively soft but tough spine(like 5160 or so). And only teeth are hardened. So if you make a knife and grind the teeth off.... your blade is simply trashed.
Blade without "Bi" addition would do much better, but even than you need to HT it to get proper hardness.
Oh, I thought it would look more like this
so what if I ask them not to bother cutting teeth that would be excellent for me, and only a little bother for them, not to mention that they wont have to cut teeth.
well really because they are already heat treated, and it could be really cool kinda like kershaw's composite knives. a 68Rc edge and 45Rc spine
but you may be right I am spending too much effort on this might as well just buy real steel.
I'm begining to realize that bi-metal blades are essentially the same as carbide tipped teeth ...so bad Idea
