Well, I figured 4 days was enough to keep my new BWM pretty and clean. I took it and my current "big chopper" and tried them out side by side.
That is my BRKT KSF machete. They were made in collaboration between Bark River and KSF in 2008. It is an 18" Ontario machete cut down to a 14" with a slight drop point, plunge line extended, blade reprofiled to a beautiful convex, rehandled using micarta with epoxy and stainless Loveless bolts, and the grip length increased, etc. The steel is incredible and for Alaska it is an awesome bush knife, with some limitations.
The contenders with one weak swing into an 8" piece of birch that was cut down last year.
3/4 through for the BWM
After
Still sharp
The curled cuts on the left are the BWM. The more ragged cuts are from the machete. By the way, the machete has made hundreds (possibly thousands) of cuts on everything from weeds to trees and has NEVER been sharpened. It STILL has the edge from the BRKT factory. Pretty impressive and speaks well for the Ontario steel and heat treat and the edge the folks at BRKT put on it.
Next I tried some typical "machete" work on some limbs and brush and as expected, the machete was better on the light stuff.
Bottom line, the machete excels at snap cutting brush and standing weeds, grasses, bushes, etc. It goes through alders and willows up to 1" like a hot knife through butter. Its lighter weight and slightly longer blade equals higher blade speed with less effort.
The BWM excels at rough chopping and would obviously do things that would destroy the machete like chopping through cinder-blocks, steel siding, cars, etc that you might encounter in a SHTF situation.
If I had a choice and the energy I would have one of each strapped to each side of my BOB.
It I had to select one to get me through it would be the Busse hands down. I don't have to do a destruction test to know it would be the survivor in a TEOTWAWKI situation.
Michael
After
Still sharp
Michael
