INTRODUCTION
Around the end of August Andy offered to design a new model with a handle sized for my large hands. He said he'd send me one to try and that if I posted a review I could buy it at a used price if I wanted to keep it, or return it if I didn't. I gladly accepted his generous offer.
A couple weeks later he posted a sketch of the Big Mitt. He proposed two versions, one with a 4-inch blade and one with a 3-inch blade. I opted for the 3-inch version because I wanted a utility knife for around the house and yard with thin stock and a handle long enough so that I could use a full, 4-finger grip. Jules (Bear71) sharked the first 4-inch version at the Friday, 9/23/16 sale.
Last Friday the first 3-inch Big Mitt arrived in my mailbox. (Pencil shows balance point.)
SPECIFICATIONS of 3-INCH BIG MITT
OAL: 9.127
Blade Length: 3.336; Cutting Edge: 3.139
Handle Length: 5.791
Steel and Thickness: 3/32, A2
Tang Type: SFT
Grind: Convex
Handle Material: Natural canvas micarta with tan liners and white pinstripes
Weight: 6.95 ounces
Blade Height at Plunge Line: 1.320
Handle Measurements:
-- at front -- Height: 1.415; Width: .865
-- at indentation for index finger -- Height: 1.090; Width: .796
-- at Palmswell -- Height: 1.214; Width: .980; Circumference: 3.75
-- at narrowest point aft of Palmswell -- Height: 1.121; Width: .832
-- at Back -- Height: 1.195; Width: .943; Circumference: 3.75
Distance from front edge of handle to center of Palmswell: 1.690
Distance from front edge of handle to balance point: 2.350
IN USE
It's been rainy here in the Pacific Northwest, but I've been able to use the Big Mitt enough to know it's going to do just what I'd hoped it could. One use will be as the blade to carry when I'm working in the woods out back, clearing out ivy, holly and other invasive species. I'll also use it as an EDC around the house. It excels as a cutter, easily slicing straight through a three-fourths-inch stack of cardboard.
IN-HAND PHOTOS
First, some photos of the Big Mitt in my left hand. I'm right handed but my right hand has some grip issues because of an old accident, so you might find these left-hand photos more useful to you. Think of it as getting two reviewers in one review.
Much of my right hand is numb, and some muscles have atrophied. The fingers are skinnier and a little shorter than those of the left hand. Only the pinky has 100 percent strength and sense of touch. I grip knife handles at the front and the back, the middle section essentially being a place to park the zero-strength outer halves of my index and middle fingers. I pinch the front indentation of the handle between the main knuckle of my index finger and my thumbpad, and hold the back end in a fairly normal way with the pinky and a fairly strong ring finger.
Here are some pics of the Big Mitt in my right hand:
COMPARING BIG MITT'S HANDLE TO A WOODSMANS
Woodsmans Relevant Handle Specs
Handle Length: 5.318
Handle Material: Evergreen Shadetree burlap
-- At Front -- Height: 1.287; Width: .859
-- At First Indentation -- Height: 1.113; Width: .728
-- At Palmswell: Height: 1.268; Width: .840; Circumference: 3.5
-- At Aft Indentation: Height -- 1.026; Width: .712
-- At Back: Height -- 1.164; Width: .800
Distance from front edge of handle to center of palmswell: 2.375
FIRST IMPRESSIONS
The 3-inch Big Mitt is the best cutter of the 30 or so Fiddlebacks I've tried. One reason for that is the 3/32 stock. The other is the big, thick handle, with plenty of surface area to bear down on.
I also like the shape of the underside indentation for the index finger. Even without a good sense of touch I can easily position my hand using that notch. That's a feature I also liked about the Bear Cub.
When I saw pics of the first 4-inch version, I was concerned that the palm swell shape would be too short lengthwise on the underside, and that it would be located too close to the front. I had, after all, become very pleased with the Woodsman's handle, whose palm swell is considerably longer lengthwise and located closer to the middle of the handle. But both are excellent handles for me.
So the Big Mitt is definitely a keeper for me. Thank you, Andy, for your generous offer. You know, I hadn't bought a nice knife in decades until happening upon Fiddlebacks. Their great ergonomics make me a very satisfied customer. I would encourage any of you with large hands to give one of the Big Mitt versions a try.
OAL: 9.127
Tang Type: SFT
Grind: Convex
Weight: 6.95 ounces
IN USE
IN-HAND PHOTOS
FIRST IMPRESSIONS
