Cliff--Any day I can inspire you to do more is a good day!Originally posted by Cliff Stamp
I should get a buffer, or at least a leather belt for the sander, or some fine finishing belts.
Will the back of that blade looks like it has some stories to tell.
After I made my last pass with a 1200-grit Trizact belt...
Using the belts stapled to wood you can make very high quality hones that are fairly cheap...the fine belts make great finishers...
I am beginning to think that the era of hones has past.
Have you tried using very fine-grit belts, especially worn-out ones, as strops?
The only time I use my EdgePro anymore is with expensive blades on which I am particularly interested in maximizing useful blade life.
Edge first is far less prone to burr formation
... if I end up with a slight burr when I'm done on the belt grinder, stropping on soft leather typically polishes off the burr
L6 edge quenched sounds like a fine blade. It is interesting that it tends to take a burr, I would not expect that unless the hardness is low, can you ball park it?
I was toying w/ the notion of making a "backwoods belt sander" by just clamping a piece of sandpaper between 2 vices, followed by a belt w/ white buffing compound. What kind of edge can I expect from this setup, compared to my current one.
I was thinking of using sanding belts in the vice, from 180 down to as fine as I could get. I dont have any proof, but a highly polished edge seems to last longer. The cutting I do doesnt seem to have a preference for the aggressive course finish favored by many.
My current sharpening set up is a Norton course/medium india stone set on an angled piece of wood, followed by a sharpmaker at a slightly greater angle, perhaps 2-3 degrees.
I would like to continue the convex flow. Would the above belt setup work?
Originally posted by Elwin
The thought has occurred to me that I would have been better off buying a small belt sander for about $65 instead of $40 for the sharpmaker and $20 for the Norton.
I recently sharpned my CRKT Crawford Falcon to 15 degrees. It took nearly 3 hours off and on w/ the course Norton.
